Upgrade to 4.0.2
Good morning all. Last night I stated the upgrade from version 4.0.0, to 4.0.2, there have been over 200 bugs fixed, apparently. I held off from upgrading to 4.0.1, as didn't want to faff around with two upgrades. Good job I didn#t. As usualy the upgrade sisn't go smooth. It would appear their bugs are in the upgrade routine. To the end user its a case of pressing Upgrade, but it tried to add items to the database that are already there, and bombs out with errors.
What I have done so far is disabled and add ons like FlashChat, and the CMS section (usually found clickin on Home on the menu Forum/Blogs/Whats New)
The forum and blogs are working fine.
Off on Holiday on Friday 12th till 22nd, so I wil be back on this when I return. If I try to get around the bug we may end up with less that what we have now before I go away.
There was a few hours outage last night from this.
2000 Trans-Am WS6 LS1 M6. (The Bat)
Corsa Cat back, 3.5" dual tips. F.A.S.T LSX Intake / F.A.S.T Fuel rails, Dynatech LT Headers / Y-Pipe / No Cats, Wisper Lid, ported MAF, Racetronix 42lb/hr fuel injectors. Hypertech 160 stat. !AIR, !EGR. Walbro 255, SPEC Stage II Clutch / Flywheel. HPTuners 1BAR SD Tune. Wide Band gauge.
389RWHP/380RWTQ ([477HP/460TQ]Flywheel) Dyno Dynamics
Photos at:- http://www.solent-renegades.co.uk/ca...00trans-am.asp
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
